Amp problems - cuts in and out.
Plutoman
<-- Yes, that's me.
Alright. This post is for my friend's 300ZX, he's running a single Jensen amp. He got it cheaply off a friend when his friend stopped using it, he doesn't have a lot of money, so getting a new amp is out. If he can't get it working, then he's just running it off the HU.
Situation - 600W Jensen amp - supposedly rated for 150 watts RMS at 2 ohms times four channels. He's running infinity coaxials that are 2 ohm speakers, gains at minimum, because they're rated for 60 watts RMS.
As he's playing, the amp will cut in and out. Usually on bass hits, but not always. You can tell when the amp light flicks on and off. Sometimes it just seems like it's skipping on a cd, but then at other times it just cuts completely off for a few minutes.
He's got a nice JVC HU, which is pretty new.
Suggestions? His battery is pretty old - I wondered if it was that. The car's an '86, so the alternator could be going out. I'm wondering about power draw. It's a small amp, though, so I'm not sure. Trying to figure out the cheapest solutions here.
first thing to do is definately check the ground wire where it goes to the chassis.make sure theres no paint under the ring terminal.i know a shitty ground connection does this.
Checked that, though I'll recheck that. I don't think that's it, though I guess it's a possibility. When checking it, I got a full good connection with the DMM.
haha happened to my car also the other day, found out it was the headunit skipping the cds when the bass gets too high. I have a 2005 jvc head unit, I guess the laser is just burning out.
same thing is happening with my jvc HU //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif. cd's have trouble reading from time to time and sound scratchy. good thing the USB connection has no problems //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
yeah, im feeding about 1250rms and when I turn the volume up to where the bass is significantly loud itll cut out sometimes, like its "skipping" sometimes it doesn't but its starting to do it more and more, so there's a good chance it could be your headunit.
The way I can tell its the problem is because when I turn the radio on, which is usually lower then cds, but turn up the bass as loud as it will go and put the volume up real loud, it doesn't skip when the bass hits.
is the HPF on? it shouldn't be affected by low notes if the high pass filter is on. The amp is probably not a big fan of 2ohm loads. is it covered up? maybe its not getting enough circulation
HPF is set at 80hz, but it's still cutting out on lower notes, they're toned down, but not completely filtered, since it's a slope. It's mostly those lower notes though that make it cut out. It could be the 2 ohm load, it's kinda funny though, when he hits the amp, it turns back on sometimes. Makes me wonder if something's loose in it. It's a Jensen, so, ya know. -.-
He plugs in his Zune, with the same problem. So it's not the laser. I'm thinking it's something with the amp, or possibly an RCA connection. The HU is only about a year and a half old. I can get model numbers for everything tomorrow.
use a DMM and check the voltage at the amp when its playing to see if its dropping at too low a voltage.also,make sure the rca's arent loose where they go into the amp.is the amp mounted on the sub enclosure?
First thing
1. how many speakers are hooked up per channel?
2. Is it bridged? If so usally when a amp is 2ohms stereo it going to be 4ohms bridged just something to think about.
No subs - just speakers. I'll check that tomorrow, it's midnight tonight. My friend would probably find it odd to see me checking out his car at midnight.
It's one speaker per channel, each speaker is two ohms, four speakers on all four channels.
I'll open it up tomorrow, too, to check it out.
Plutoman
<-- Yes, that's me.
Plutoman
Kansas City
Plutoman
vegang
vegang
