amp problem
Chances are it is a problem with the amp, I would call the place you bought it from tell them about it see if thye have any recommendations if they don't bring it back and get a new one
Originally posted by indosia If you only hear bass make sure the crossover is set to full range.
Yea OR that the signal you are using is full range. If it isn't then make sure your signal isn't x-overed too low.
There is a great repair place in atlanta called high-end car audio repair center their address is 1919 metropolitan ave atlanta Ga. 30315 they have very fast and precise service i highly recommend them. their # is 404-763-2005 or 770-473-6556
AUDIOPHILE4LIFE
ps their prices are great !!!
Using a Y RCA to split signal from amp to amp to give both amps the signal they need from the HU and subs in different /separate enclosures tuned...
660
Fully test it without the ACR-1. TBH it sounds like an amplifier issue. Try connecting your phone direct to the amp via a 3.5mm to RCA cable. If...
699
If a sub's voicecoil fails, it will usually drop impedance causing too much current to go back to the amplifier. The amplifier then protects...
15
Have you checked the fuse block. With time, tight connections can loosen and cause failure. Refresh those contact points and test again. Remember...
140
Grand Am
Grand Am
dallas tx.
audiophile4life
    May 18, 2024
    May 18, 2024
