amp powering question
unknown00
TX
i have a cadence TXA-1502 powering a 8" JLw3v3 and it is set at 300watts at 4ohms but i don't want the sub handling that much. i only want the sub getting 200-250watts...i have the input gain set half way and bass eq set at about +10 dB (max is +12 dB) with the HU bass on max. should i be fine?
so why would you recommend me adjust the gain instead of bass when i was trying to reduce power to sub? sry for the n00b questions...still confused when bass boost should be off
because with boost on, one frequency and those close to it will be louder than the rest of the range......
stupid question- how the hell do you measure voltage to sub? i just bought a dmm and i have negative at negative and positive at positive on speaker wire and it just keeps showing 0
unknown00
unknown00
TX
dman4486
