Amp overheatting??
Sachmo12345
recently my amp goes in and out. i am pretty sure that it is due to overheating, i have an MTX 801d and all last summer it worked fine. i mounted it to me box when the temperatures were cooler so i think that the hot weather might have something to do with it, but i could easily wrong.
Post a pic of the install, so we can see how its mounted.
If I had an overheating problem I would either move the amp to a better spot or modify it with a couple CPU fans.
ill be driving around bumping it for a while and then itll the amp will cut out but the music keeps playing then after a little bit itll come back on. it doesnt come on when i hit a bump or anything that would make me think that there is a loose wire
i do have the gain all the way up but it isnt loud at all with it any lower could it maybe be miswired to show 4 ohms not 2. i really do mean that it isnt loud at all with the gain any lower at half way the sub barely even moves
Well now that you say that you have the gain all the way up, its kinda self explanatory why the amp is over heating //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif Any amp will over heat if you run it with the gain all the way up. The mtx 9500s are very power hungry subs, and they need about 1000+ watts to start getting performance out of them. They are very inefficient, and ide suggest you get the mtx 1501d amp (1500+watts) for that one 12. Seems to work good for the 12 in the installs ive worked with.
Sachmo12345
Sachmo12345
Dayton Ohio
Mackenzie
