Amp only coming on in tuner mode
So I just set up my system in my truck. Got everything all wired up. Turn on the radio..BOOM..little bump, adjust the amp for my subs, everythings good. Switch over to a CD... nothing...switch to AUX nothing. All my wiring is right. Like I said the amp turns right on in tuner mode. And oh btw the headunit is a Kenwood kdc-mp4032 single din.
Some help or advice.
PLEASE &THANK YOU!! Have a nice day.
what amp? are you using rca's for the signal from the deck to the amp? might be a dodgy deck, make sure you check all your settings on the deck, worth even reseting the unit
The amp is a old school soundstream PCA2000D. And yes I'm using RCAs. And yea I was thinking about resetting the unit. Also with the antanna wire, good point. Didn't think about that. That's probably what I did knowing my luck. Lol
did it fix it? Im sure it did....just check up
Yes it did fix it everybody. But once I cleaned up all the wires and mounted the amp, went to go test it now I have another issue, amp will not come on. But I will wait till later once it cools down to go mess with it.
kcurry
kcurry
Wesley Chapel, FL
Side Show
