amp not turning on ???
your remote wire should be connected to a wire off the back of the head unit? and if thats not possible, a switch connected directly to your battery. Your ground must be on a clean, unpainted metal surface. Be sure your inline fuse isn't blown if you have one.
Grinder
yes you did everything wrong, thats why the amps not turning on
1: change the remote wire to a PROPER 12V switched source
2: change your ground from where ever you put it under the "spair"
did everything you guys said.
replaced the ground wire and ran the remote wire directly to the 12v
then i tapped it into navi and it still doesnt work =X
can it be the amp ? i just replaced both fuses also.
Kinda stupid question but does your car still start? I ask because when you wired the remote wire to the cigarette plug it could have drained your battery. The remote wire tells the amp when to turn on, so when you had it hooked up to a non switchable source it could have powered the amp and drained the battery.
Take it to a shop....you probably got screwed on it
my other amp works fine.
also my car turns on.
i was just driving it to go buy some fuses because i thought that was the problem.
seller didnt respond so i wrote a dispute on him with paypal.com
daicacharco
daicacharco
San Diego. CA
daicacharco
