Amp not pushing
Disconnect the leads to the subs and hook up a 9v battery, it will allow you to check phase of the subs to make sure they are the same. You can also measure you OHM with a DMM, not always 100% accurate but should identify any immediate problems. What are you using for signal (HU) and power wire size?
So you don't think it is the amp because my amp is under warranty for about 3 more weeks and if it was somwthing with the amp I could get a new one?
Did it work before in the same configuration, or has it never worked for you?
* First guess is sub wiring's out of phase
* Second is your filters are set incorrectly
* Third is your input signal; How are you getting it to the amp? Line-converter?
There is a line converter and the Filters are set right would what would make them out of phase there wired from a diagram i found online
newyork2050
newyork2050
ny
1phatclipse
