Amp mounting ?
ace_800
I had a JL and a Zapco until recently installed under my spare tire panel, which is above my spare in the trunk of my Murano. They were not to heavy(12lbs) and they could be supported by the panel and screws. Now I have 2 PG Xenon amps(20lbs each) and I need to know if there is a way to strengthen the panel. It is patical board I believe. Someone on my Murano site mentioned an L-Iron screwed to the panel and the amps rivited to the L-iron, but is there a easier way? The panels only about 1/2" thick and I don't have much room to add anything between the panel and the amps. I would like to keep the screws hidden if possible, (ie..I would like not to have to screw all the way from the bottom to top)
Yes, you can get it at home depot and lowes. It usually runs about $30 per gallon, but you wouldnt need nearly that mich. They probably sell smaller quantities. Swing by and check out what they have.
you should be able to get a quart at walmart for about $10 it is cheaper at walmart than at home depot and it will be the same resin, while you are at it might as well add some chopmat to it
ace_800
ace_800
Okinawa, Japan
UMGixxer
