could be plenty of reasons why. what amp is it?when my heeadunit is turned on my sub makes a solid loud noice, why
the problem stops when the rcas are disconted. i tried differnt rcas with the same problem accuring.does it still do it if you disconnect your rca's? If so then its an amp problem.
If it stops doing it then its something in the h/u rca setup. Maybe your rca is grounding out or something.
try taking a wire to one of your rca's at the amp and running to a ground area //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gifthe problem stops when the rcas are disconted. i tried differnt rcas with the same problem accuring.
my amp is a soundstream 1002 old school its blue . im going to check all the wiring to make sure the is no grounding were there shouldnt be. one think i think is odd is the problem stop if i push on the switch for balanced or unbalancedcould be plenty of reasons why. what amp is it?
could be ground problem. rca problem
ground your rca's //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gifmy amp is a soundstream 1002 old school its blue . im going to check all the wiring to make sure the is no grounding were there shouldnt be. one think i think is odd is the problem stop if i push on the switch for balanced or unbalanced
are you saying unplug one rca and touch to bare metal?jus like i said in the previous post. take a wire from one of the rca's at your amp and run that wire to a ground area. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
