soundstream amp doing some wierd sh1t
sinosic
Idyllic Enclosures
i have a soundstream rubacon 1002 the blue old school one. when i turn my headunit volume all the way down there is sound coming from my sub. its not engine whine cause it does it with the car on and off. the sound is low rumble kinda. i tried only left rca input w/ switch to mono, i tried both rcas in w/ switch on sum. im messed with the gain that makes the sound go up and down as adjust the gain. could it be sh1tty rca cable? i cant figure this out any help is much apreshated
ive seen some amps including a soundstream that did that when the gain was set too high. I know you said that you adjusted it but turn everything down including bass boost, subsonic (if it has that) and gain and set the gain using the tutorial. Is it a new amp or have you been using it for a while. Also what components are upstream from the amp. Headunit, preamp, epicenter, line driver, etc.
i set the gain like the manual wants. the amp is new to me but is a old school soundstream amp rubacon 1002. my headunit is pioneer deh p6400, no preamp, no apicenter, no line driver. conponites are stock monsoon which has a stock amp in the trunk.
no when i unplug the rcas the sound is gone
Ok its not the Rubi then something upstream, I'd say look for a better ground on your HU (try not use the one from the old stock HU), change out or ground your RCA's, like already said.
sinosic
Idyllic Enclosures
sinosic
roseville,ca
Blazemore
