Amp lights off no audio after battery died.
I think i found the problem. I was cleaning the corrosion off all my connectors. I folded down the other half of my back seat and found this!
//content.invisioncic.com/y282845/emoticons/nutkick.gif.acc8dcd6c1bd27fba0cbeda5b212085c.gif A whole second set of wires going into the box thing in my trunk with the subwoofers in it.
//content.invisioncic.com/y282845/emoticons/nutkick.gif.acc8dcd6c1bd27fba0cbeda5b212085c.gif That were disconnected. //content.invisioncic.com/y282845/emoticons/nutkick.gif.acc8dcd6c1bd27fba0cbeda5b212085c.gif
So I connected them to look like the other set.
Lights! //content.invisioncic.com/y282845/emoticons/clap.gif.178cba2c538c68e720c727fcb024b19c.gif
Speakers work now!
Although, I did try putting the old fuses back in and it stopped working so apparently those did need to be replaced.
I would like to thank akheathen, loudrc, CRXBMPN, and Spooney for their help.
Thanks you guys!
oh, that is cool, it went into protect mode. normally, a protect light illuminates, letting you know there is a problem. oh, and i have been in ca since the 90's, too, and have seen caps pop more than i care to see happen. 2x personally. it usually only happens, when there is a battery discharge in freezing temps, so i tend to be tentative about powering up an amp in question. i've been able to save a couple, and replace the caps, and some ended up needing full power fet replacement. anyways, nice amp you have there, and have fun.
PeoplePhobic
PeoplePhobic
GA
akheathen
