PeoplePhobic
Hi. I'm new here. looking for some advice.
I have a 2004 Cavalier with a Pioneer DEH-6100BT and a JBL CS300.1 and two 12" or 10" Subwoofers. Everything else is factory.
I returned from a long trip and found my car battery was dead. It is fairly new so I charged it up with a AC charger until it started then let it run a while.
While it was running I noticed my head unit (Pioneer DEH-6100BT) had lost all its settings. //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif Also my subwoofers were not working. My JBL CS300.1 has 3 LED lights on the top of it that usually light up blue. All three of these lights are out.
Is there a reset button or something i need to press on my amp? Maybe there is something i need to turn on in my head unit to get the amp to power on?
i checked the manual and see that there are some fuses in my amp which i will check after i get some sleep (it's 2:00 am). Also there is a big red wire that says rockford fosgate (or something) and has a big fuse in it near my battery. That fuse looks fine. There is some corrosion around my battery terminals but i've seen a lot worse.
In my amp's manual it says No audio (power leds are off) is likely cause by no voltage at BATT+ or REM terminals or bad or no ground connection and it's solution would be to check voltages at amplifier terminals with VOM.
Also, in browsing through the manual i noticed this in my amp's install guide:
"Power Connection: Connect a wire (see chart at right for appropriate gauge) directly to the vehicle’s positive battery terminal, and install an appropriate fuse holder within 18" of the battery terminal. Do not install the fuse at this time. Route the wire to the amplifier’s location, and connect it to the amplifier’s Positive (+12V) terminal. Be sure to use appropriate grommets whenever routing wires through the firewall or other sheet metal. Failure to adequately protect the positive wire from potential damage may result in a vehicle fire. When you are done routing and connecting this wire, you may install the fuse at the battery."
Should I have pulled this fuse when i was charging and boosting the battery to start my car maybe?
I'm new to car audio and this is my first system. The amp and woofers were a gift from my brother that came out of a truck he got when i was growing up that we had some good times with so i don't wan't to just get a new one. What should I check to get this thing going again? If it's not something i can fix can someone recommend a place to have it repaired so i can have my same amp back?
Any input would be appreciated.
