Amp keeps popping fuse.
TaylorFade
I fail.
I have a Cadence A7HC running at a 1ohm load. The amp has no onboard fusing but I have an inline from the battery and a 60A at the distribution block for it. Under pretty normal listening conditions it is blowing that 60A fuse. The amp is not getting hot and it has yet to go into "protect" mode. Do you think it's safe to go up on the fuse? Not 100% on the rated output of the amp but I've seen it rated at 1200-1400w @ 1ohm. Is 60A normal for this rating?
P.S.- when I say "normal" listening conditions, I mean rap for the 45 min. drive to work.
Hey I'm running a SAZ-4500D and it keeps blowing my 30 amp fuse. Helpz0rs!!! Wtf dude. Lol. I was so right when...... I mean ecrack was so right when he dubbed you "TaylorFail". JK man. You're going to have to upgrade fuse blocks. You're probably using an inline fuse. The biggest they make are 60 or 80 I'd guess. Just go to your local audio shop and get an ANL fuse block and ANL fuse. 100 amp SHOULD do it.
Hey I'm running a SAZ-4500D and it keeps blowing my 30 amp fuse. Helpz0rs!!! Wtf dude. Lol. I was so right when...... I mean ecrack was so right when he dubbed you "TaylorFail". JK man. You're going to have to upgrade fuse blocks. You're probably using an inline .The biggest they make are 60 or 80 I'd guess.. Just go to your local audio shop and get an ANL fuse block and ANL fuse. 100 amp SHOULD do it.
My inline fuse is 200 right now on my big amp :fyi
TaylorFade
I fail.
TaylorFade
Baton Rouge, La.
Johnny Law.Lulz
michigan born
    May 14, 2026
michigan born
    May 14, 2026
