Amp keeps cutting out/ speaker blown
miker
Alright... I just installed this Sony 4ch amp.... I used it to power my Infinity reference 5.25's in the front.. They say they take 45rms... I said **** it, they are old and sound like shit. so I gave them about 75 each... ONE blew the other is fine, but now when I turn the volume up to about 25 the amp turns off, but my subs are still running... I have checked all connections, they are fine.... Also the amp is bridged, and the gains are about 3/4 way up.
Anyway, I'm not too worried.. I got the amp for 25$, I do want it figured out though...
really? I have the high-pass filter on, frequency response turned all the way up, gains at ~ 3/4....
Do you think that the amp just can't take being bridged?
whats it bridged at ?
i assume its 4ohm stable bridged.. and 3/4 maybe too high depending on ur output voltage on ur headunit
I would assume/ hope so...??? my output voltage is 2v... But my sub amp is running fine, and that is at 1600w...
is it the same amp or different ?
i'm not saying you have low voltage "in which this case everything would shut off"
i'm saying ur trying to get more power then what it'll put out...
I don't know the technical behind it but I do know a blown speaker if still hooked up will put a amp into protect. Maybe the coil laying down in the pole piece grounds out. dunno. But I know I have had a few subs that blew and it clipped the amp out. disconnect that one from the amp bet it quits
miker
miker
Wayzata, MN
vehementSPL
