amp is buzzing
To truely see if thats the case...hook the system upto another headunit and see...if its still doing it I would think of possibly running the ground for your amp all the way back to the negative of the battery with 0-gauge if possible..
first, i would ground the head unit myself, and not use the factory harness for ground. i would also make sure my ground on the amp is sufficiently touching a good bare metal surface and bolted down tight.
ok i did check the ground and it bolt down and bare metal i wire brush on a drill and went to town on it. where would be a good place to ground the head unit off at without picking up road noise
Connect an Ipod or a portable cd player to the amp if you still get noise then it's on the amp side, ground, connectors, etc. If you don't then it's the HU
Mattp13
Mattp13
Manassas, VA
duce2k
Mike Mccabe
