amp installation
0 gauge is ridiculous ha. If you have legit 4 gauges you should be fine. My buddy ran 2 ARC flatlines that draw 2000 Watts rms each and his 4 channel off of one 4AWG wire and then using a distribution block to hook up both amps
your buddy is and idiot. 1/0 is good for about 300+amps. 4 gauge is good for about 150amps. you dont want to pull more current then the wire is rated for and if it was a true 2000rms then he is pulling over 200 amps, or just not ginving the correct amount of power to the amps. either way dont skimp on wiring
op if you are going to upgrade in the future, might as well do 1/0. if not, id say 2 or 4 gauge will suffice
Wow, he must've got the super secret 2,000 watt version of the Flatline. I'll bet he's running a SE 4000 too, huh?
KBCnick
KBCnick
iowa
misfit138
BP1Fanatic
BP1Fanatic
