Amp installation kit 1000w
  • 4
This kit is cheaper, and it is just as "complete" as the other one.
http://www.knukonceptz.com/productDetail.cfm?prodID=eKo-K4
As far as where to ground, it is best to keep the ground cable under 3 feet in length. You'll find that knukonceptz supplies you with around 3 feet of ground cable, and this is why. It would be in your best interest to ground it to your chassis. Just make sure you use a wire brush or something like that to scrape off the paint so it's bare metal contact.
What size speaker wire would I need? would 16 gauge be ok or should I get 14? I definitely want to be on the safe side.
154
387
  • Locked
690
JoeSVT
JoeSVT
SAN BERNARDINO
.::DuD3::.
maylar
    Jun 2, 2024
    Jun 1, 2024
