Amp installation (disregard last thread)
BulldogSr04
Ok, i got the power up and running. But now theres no sound... I got 2 rca splitters for each rca jack to seperate the rcas goin to both of my amps(2 rcas for my bass and my kicker 300.4 says i need 4 so i just split it more). i have sound to my bass but none to my other speakers. I'm pretty sure i have the speakers wired right but i dont know whats goin wrong. any help would be appreciated.
thanks
yeah.. thats what i did, it all matches up. what are preouts? the only outputs i see are all filled w/ speaker wire, rcas, power, ground, and remote. when i get my car back from the shop ill try and double check all of my speaker wiring but i dont see why nothing would work.
Ok... I have bass to my mids but nothin else, is there any rca wires that filter out all things above a certain lvl? I had my bass installed professionally so maybe the people might have put in some treble blockers or sumthin ill have to check that, is this a procedure that you have ever heard of?
The signal coming from the head unit must be full range. Once you split the signal into 2 sets of rca's, One set will need a low pass crossover and the other will need a high pass crossover. If there is a low pass crossover before the splitters, you will only hear bass. If possible use the crossovers in the amps.
ok, i have narrowed it down to two things, either my HU (see below) isnt sending out all the frequencies thru the rca cables or my amp isnt filtering properly. how can i change the output from the rcas to send a full range? thanks for all the help
BulldogSr04
BulldogSr04
Jennings, LA or Baton Rouge, LA
BulldogSr04
