Amp install
  • 4
gmann42
MA
I want to know if i got screwed or not. I payed 120 to get an amp installed to my 4 t1693s and the installer did not run all new wire to my speakers...he just spliced off the factory ones. Is this normal?
Depends on your viewpoint I guess.
Did you get a written estimate up front so you knew exactly what you were paying for?
Did you discuss the install, what he was going to be doing, what materials and wire, etc before you agreed on the $120 estimate?
What kind of car is it and how much modification was required to install the speakers? If a lot of mods were needed, $120 might be a bargain.
At any rate, if you are going to light those speakers up to full power, I would make sure you replace the factory wiring eventually.
If you didn't agree on specifics of the job *up front* it is going to be hard to argue for the installer to do it for free. Maybe he will, maybe he won't.
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
Sounds like your front stage is overpowering your sub stage/ Weak sub stage. Is this a 4dr. Sedan or a Hatchback WRX? Where do you have the sub...
22
problem was the LOC burnt out when I had touched cables. got a new LOC and now all is working. have to get the gain right, lights flickering with...
Rockford Fosgate R2-750X5 I just bought a audiocontrol converter and hopefully that will help
956
gmann42
gmann42
MA
CrossoverOre
    May 16, 2024
    May 16, 2024
