Amp install critique...
mlo
USA
I have uncovered some gremlins after a paid install by a shop on a complete system. Here is a photo of the amps and there mounting. I was hoping to run this by some of you that would know what to look for and hopefully fix anything that is not up to par. I noticed the installer used a small head black painted screw for the ground. Should that be replaced with something more akin to the ground bolt in the cable lug next to it? TIA
meh ive seen worse lol, doesnt look like the grounds are on bare metal and the bass knob... um duno why its back there and if thats where u wanted it they could have at least mounted it upside down so u dont have to jam your fingers between it and the amp to turn it on..
A ground needs more than 1 screw, esp if its two amps. If you can swivel the ground around the screw, then you need to screw in 1-2 more screws.
I wouldnt have used that ground thats above it either, its always best to make your own grounds for your amps, seperately at that. Other than that, he made you an mdf board for the amps to mount to, used zip ties, I wouldnt say its a bad job, just a quick 6 hour job.
And if you're good enough to detect installation errors, why didn't you install it yourself? Save some monies.
I posted the photo here for those of you "capeable" of detecting any detrimental errors. I have no experience in this field and had another guy point out the small painted ground screw I referenced.
I'm not parading this as anything special. It was never intended to provide anything other than functional and pleasing sounds on my daily commute. There is an interior panel that covers everything up so nothing is visible.
I was never asked by the installer about the Bass knob location. I'm learning about these things. Would I find myself wanting to adjust this...why/when?
TIA
Look how long those ground wires are, could be shortened. Horrible job on wiring. I would of made holes in the mdf for the wires to go through at least and that would of hide most of the wire. And lol at the bass knob.
mlo
mlo
USA
jmanpc
