amp inline fuse help
Also, I like to use a distro block before the amps and fuse those runs to match my amps as well. For example, I have a 200 amp inline fuse and then my distro block has an 80 amp fuse to my sub amp and a 60 amp fuse to my 4 channel. I’m upgrading soon so that is why my inline is bigger.
What size wire? Your amps will release their smoke if they overdraw BEFORE they start a fire, so the fuse on your constant wire is to prevent wire fires. I recommend using the maximum fuse that the wire is rated for.
Codad
CarAudio.com Newbie
Codad
usa
Louisiana_CRX
