Darrin2576
I just got my first car 4 months ago and I am looking to get an amp and a subwoofer. I am looking to spend about $450 for some subs, amp and a wire kit. I found a pair of kicker 12" comp vr's wired at 4ohms (info below) for $300. I don't know what amp or wire kit to get for these for around $150, I don't know much about the ohms and if higher or lower rms amp is needed. I believe that they can be wired to 2 ohms. Anyone think they can help me out?
Subs:
Dual 12" CompVR Subwoofer Enclosure
Subwoofer Features:
Dual 12" Comp VR Series Loaded Enclosure
Power Handling:
Peak: 1600 watts per system / 800 watts each sub
RMS: 800 watts per system / 400 watts each sub
Enclosure impedance: 4 ohms (Wired internally in series/parallel to final 4 ohm impedance)
Injection molded SoloKon cone
Ribbed Santoprene surround
Double stitched surround for enhanced cone-to-surround strength
Extra strong adhesive and stitching prevents the cone from detaching from the surround
Spiralead tinsel lead technology weaves the tinsel leads into the spider
Progressive-roll polycotton spider
Super rigid cone and 360-degree back bracing eliminate distortion
Sturdy steel basket holds the subwoofer mounted firmly
Steel basket features perimeter venting around the dual voice coils
Large, high-mass pole piece for dissipating potentially damaging heat
Strong spring-loaded terminals
Newly re-designed 2010 basket structure
High-Temperature 4 ohm voice coil
Powerful rear magnet
Frequency response: 25-500 Hz
Sensitivity: 86.9 dB
Enclosure Specifications:
Subwoofer specific ported enclosure for the CompVR subs
Tough and durable wooden enclosure
Covered with dense gray carpet
Front baffle has a monogrammed, carbon fiber design
Kicker emblem on the front of the box
Ported and tuned to the subwoofer's specifications
Built from durable 3/4" MDF construction
Dimensions: 32-11/16"W x 16-1/16"H x 14-1/8"D(Top) x 17-3/8"D(Bottom)
Subs:
Subwoofer Features:
Power Handling:
