amp help
lilbone44
OK looking for help with a planed setup. looking to get 2 XL 15 (DC audio level 4 XL for anyone that don't know who make these) around 1500 to 2000 wRMS a pieces in a 98 Mitsubishi eclipse wall off. looking for any help with what kind of amp out there that will do rated power at least. not looking to spend more then 350ish a pieces on amp IN THE NEAR FUTURE. any help, comment, or suggesten welcome.
1500 - 2000w and $350 per piece?
Pair of:
Sundown SAZ-1500.1D's, used
Audioque AQ2200D's, used
MBQuart DSC1500.1D's
MBQuart DSC2000.1D's
Audiopipe AP15001D's
Or you could just get a single:
Sundown SAZ-3000D/SAZ-3500D
Audioque AQ3500D.1
Crescendo 3KWP
Crunch GP3000D
Audiopipe AP30001D
I hope you have the electrical to back it up. The single amp route would be my choice - there are a ton of 3000-4000w amps for sale RIGHT at your price point over at CACO. In fact, there's a SAZ-3000D for sale for $525 SHIPPED right now, and an AQ3500D.1 for $600 SHIPPED! Both of which are CHEAPER than your $700 price limit for the amps.
2 audiopipe ap15001ds, can buy new for 160 shipped a piece or a Crunch GP3k pro, put out similar power to sundowns, etc. at a lower price. Have heard good things about the AP30001Ds too, basically two ap1500s strapped. I'm with Crysismaker and Darkscorpion on running a single large amp tho. Easier to find and easier to set up.
Pair of:
MB Quart DSC1500.1D's
MB Quart DSC2000.1D's
Audioque AQ3500D.1
Crescendo 3KWP
Crunch GP3000D
Audiopipe AP30001D
are any one of these .5 ohms stable. I'm just what it get real watt for dollar out of an amp this time.
got a Alternator price quote and wanted to know if there anything cheap then 624.00 + shipping.
Dear Audio Enthusiast.
Here is our quote for your HO Alternator!! HO builds super high output alternators with the finest, highest quality HO® certified parts and components. Our one-year hassle free warranty reflects our commitment to excellence. HO's Research and Development is constantly seeking new ways to improve HO® alternators and other product's performance through field-testing at local and National dB drag, USACI events. This provides the valuable data necessary to build the finest High Output Alternators for your audio and industrial applications.
Your custom build unit is described below:
Application: Import with Denso Case
HO Alternator Part # Denso Case Style,
Rated 170 AMP @14VDC nominal, per spec sheet attached. ......................... $624.00+ Shipping.
http://www.highoutputalternator.com/PDF/Web%20PDFs%20-%20Denso.pdf
This unit will directly plug in to your existing harness and power connectors. No need for brackets or modifying the wire harness. The only change you will make is an additional output wire from the alternator output post to the battery, and an upgraded ground wire from the alternator to the battery negative post. These should be at least #4 wire.
General Installation guidelines are included with each unit. We also have tech support available for help should you require it.
Price for this unit includes our one-year hassle-free warranty.
Freight Costs
Fed Ex Ground........................................$9.00
Fed Ex Second Day.................................$45.00
Fed Ex Overnight US...............................$75.00 to $125.00 (Depending on Location)
Payment terms are per major credit card.
Please call or email if you wish to order. Thank you for considering HO Alternators.
Darla Roe
Sales Coordinator
H.O. Alternators
1.877.422.3337 ex 113
lilbone44
lilbone44
Gainesville' fl
lilbone44
