Amp help
snowshreder32
Im at the point of buying a Kicker zx1000.1 but just came across a Phoenix Gold which seems to be reasonable power for the price...any suggestions?
Kicker=$300 PG=$200
Phoenix Gold R15.0:1 Car Mono Amp Class-D
500W x 1 @ 4 ohms
1000W x 1 @ 2 ohms
1500W x 1 (2 ohm mono) max power
Fuse Rating: 2 x 40 amps
Frequency Response: 20-350 Hz
High efficiency Class "D" monoblock amplifier
18dB variable LP crossover
18dB variable subsonic filter
Low Pass Level port (LPL)
Grained aluminum insert
Carbon fiber badge, backlit with blue LED
Optional neon inserts for all amp models
Overload and comparator circuitry
Full range thru output
Remote monitoring Display (RMD) port
Twin "T" bass circuitry at 45Hz
Dimensions: 14.5L x 10.875W x 2.25H
snowshreder32
snowshreder32
OP,KS
snowshreder32
