amp gurus needed!
hunter121
Dude...I'm searching!
Hi all I have a few questions regarding this amp http://www.sonicelectronix.com/item_4335.html
If I understand correctly (god forbid //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif ) I can wire up a pair of subs to 1ohm on the sub channel and on channels 1-4 keep them at a 4ohm load or attempt to wire them to 2 ohm correct:uhoh: ? Also how do you wire up 4ohm speakers too 2ohm out of curiosity? Is it the same as wiring up subs with svc's? It is also my understanding that i can hook up a directed d1200 mono to this to get added sub out put...if some1 can maybee try to explain this in moron terms to me that would be great //content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif Well thank you all for helping if ya can I appreciate it...Hunter121
yes you can get a 1ohm load of 600 out of the sub channel and on the 1-4 channels you can get
80 watts x 4 chan. + 250 watts x 2 chan. @ 4 ohms
RMS Power Handling: 125 watts x 4 chan.@ 2 ohms
Voa you are either stalking me or are one badasss mofo....Thanx for taking the time on awnsering all my questions on my topics on this site i greatly appreciate it. Hunter121
hunter121
hunter121
washington
VOA_NIGHTMARE
michigan born
    May 14, 2026
michigan born
    May 14, 2026
