Amp goes into protect mode- burning smell and spark at speaker wire!
  • 2
jdwarre
hey everyone!
So I am having a problem with my amp.
My current setup has been working great for the past 2 years, zero problems until last week..
I was going along and then boom my sub cut out and I realized my amp had gone into "protect mode".
I turned off my car and then turned it back on and everything was fine until I turned my volume up and them boom.. again.. sub cut off and the amp went into protect mode!
I unhooked everything from the amp, re-connected it all, tested it out and whenever I play my stereo at loud volume, there is a spark on my positive speaker wire where the amp is then it goes into protect mode and I can smell plastic burning..
Any suggestions on how to fix this please?
Thank you very much in advance!!
Recheck where your ground is connected to the body of the car. Sometimes they can get loose with the bass vibrating the panels. It wont hurt to check your battery connections at the same time also
Hopefully none of the mosfets or voice coils got fried. Take out the subs and check their voice coils to see if they got burned. Also check their resistance with a multi meter in ohms
16.6 is way too high. That will destroy an AGM battery. What alternator brand did you use? Sounds like a voltage regulator issue. Are you...
151
  • Locked
350
Amp
348
jdwarre
jdwarre
United States
AndrewHD
audiobaun
    May 19, 2024
    May 19, 2024
