amp gain
drifterman33
ok so i tunned my gain to the specific voltage using a dmm which read 31.6 ac volts....I wasnt sure on if i did it correctly so then i took it to circuit city and the guy there put in his music and then turned it down alot.....i am wondering if my setting was good or was the guy at circuit city an idiot.....
because they are basically the only car audio shop that is close to me....and i didnt think that i did it right because I had to turn it up so high...........I really am looking for SPL not SQ and the guy at CC turned it down for SQ....what do you think i should do?
so having the gain turned up that high wont send the amp into clipping?? Also I think i have to turn it up that high because my hu has weak pre outs...so is it a good idea to turn it back up??
it shouldn't my head unit has weak preouts also my max unclipped preout voltage is 0.08 and i set my gain with everything flat at that volume number on the head unit that reads that voltage then set my gain to w/e i want 400 rms for my kicker and i have no problems with clipping at all cuz i set it with a 60 hz 0db tone, i thinkyou'll be fine with it up, just watch the sound quality of the music.
Your max unclipped preout voltage is less than a tenth of a volt?
Am I reading your post right?
And if so - what model Pioneer HU are you running?!?
drifterman33
drifterman33
Hell (aka Guerin)
luvinthebass
