amp fried? :/
09civic
so last night i was taking my friends home and the sub cut out. it wud only turn back on if i turned the hu past 20. so the next morning, it doesnt work at all. i take the sub out of the box and the wiring was fine. i hook the sub up without the box and it doesnt move. so i thought it was the sub. so i take it my frends house and he hooks it up to his amp and the sub works fine. my amp light stays on and the fuses are fine so idk whats wrong with it
yup... looks like you smoked a resistor, and a couple small capacitors (from what i can see in the pics)
kinda hard to tell for sure in just a pic... but my best guess, from what i'm seeing, is that you burnt part of the board. cant really tell unless you see the other side of the board... but pull the board out, and look where the components i marked are located... and look at the solder trail... if its golden/brown... you most likely fried it
o ok... well thats about the only thing i could find on the pics that would say its burnt... that resistor still looks like it got melted a lil bit (but it might just be the pic).
like i said tho... the easiest way to figure it out, is take the board out, and check the solder tracks on the other side... pretty easy to see on the track side
so thanks to pro rabbit, i found out my amp is not fried. it is either my RCA cable or the RCA's on the back of the hu. i found this out by taking my aux and putting directly to the amp and play it like that and it worked fine. im hoping it's just the RCA cable so i don't have to buy a new hu
//content.invisioncic.com/y282845/emoticons/wow.gif.23d729408e9177caa2a0ed6a2ba6588e.gif
He has a headphone to rca converter for his aux input. So he just plugged that into the amp using the MP3 player as a signal source. Thus the RCA cables or the head unit are what is at fault for no sound.
09civic
09civic
Melbourne, FL
09civic
Mike Mccabe
Giles
    Jun 27, 2026
