Amp for Kicker L5's
ryanbssc29
I need an amp for 2 12 dual 4ohm Kicker L5's. If possible keep it to only one amp, and no more than 500 dolars.
Kicker L5's specs:
Model S12L5
Outer Frame Diameter, in (cm) 12 9/16 (31.9)
Nominal Impedance [Zn], ohm [per coil] 2 or 4
Power Handling Watts, Peak (RMS) 1200 (600)
Sensitivity [sPLo], dB @ 1W, 1m 87.9
Effective Frequency Range, Hz 20-100
Mounting Depth, in (cm) 6 3/4 (17.1)
Resonance Frequency [fs], Hz 32.2
Equivalent Volume [Vas], ft3 (L) 2.41 (68.27)
Net Displacement, in3 (cc) 2215 (135.2)
Moving Mass [Mms], oz (g) 7.44 (210.9)
Magnet Weight, oz (kg) 77.25 (2.19)
Any suggestions?
You could always go with an Elemental Designs NiNe.1. I hear they're a bit underrated so you may want to go easy on the gains.
http://www.edesignaudio.com
And don't let the eD trash talking in the other threads throw you off, they make some nice amps. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Some suggestions KICKER 1200- ORION 1200 D - PHOENIX GOLD XEON 1200 CROSSFIRE 1000D ED 9-1. ALL these amps listed would work perfectly. Personley I would stay from HIFONICS they dont impress me at all.
sorry for the stupid post...had a friend over on my name looking at the forum...he's not the brightest character around...but andon did a nice job of clearing things up so i'll just keep quiet now lol //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
never heard of anyone doing it to a L5 but i know they run at 2 or 4 at 600watts. if you run the 1200.1 at 2ohm and each sub at 4ohm you should be good
what the hell does this mean? i got confused in a hurry here.
but to answer your question, yes run each sub in parallel and then together and youll end up with a final load of one ohm and a total power of 600 watts or more per sub
ryanbssc29
ryanbssc29
Waveland, MS
ryanbssc29
NorthFramingham
    Jun 30, 2026
