Amp for Kicker L5's
ryanbssc29
I need an amp for 2 12 dual 4ohm Kicker L5's. If possible keep it to only one amp, and no more than 500 dolars.
Kicker L5's specs:
Model S12L5
Outer Frame Diameter, in (cm) 12 9/16 (31.9)
Nominal Impedance [Zn], ohm [per coil] 2 or 4
Power Handling Watts, Peak (RMS) 1200 (600)
Sensitivity [sPLo], dB @ 1W, 1m 87.9
Effective Frequency Range, Hz 20-100
Mounting Depth, in (cm) 6 3/4 (17.1)
Resonance Frequency [fs], Hz 32.2
Equivalent Volume [Vas], ft3 (L) 2.41 (68.27)
Net Displacement, in3 (cc) 2215 (135.2)
Moving Mass [Mms], oz (g) 7.44 (210.9)
Magnet Weight, oz (kg) 77.25 (2.19)
Any suggestions?
I have three 2005 Solo L5 12"s in a sealed, glassed enclosure, and I picked the JL 1000.1
I am triyng to find one on ebay, but if not Ill get it new next friday. I cant wait to hear it beat my L5's //content.invisioncic.com/y282845/emoticons/smash.gif.499e08a4a35ffaf54f4c8194fb8fe8ed.gif I will let you know how it sounds.....
Here is the thread I started on amps for my L5's, maybe this will help
http://forums.caraudio.com/vb/showthread.php?t=96229
i would suggest searching for an mono amp that does 1ohm stable. both subs take 600 a piece = 1200. there are many amps that do 1200 watts 1ohm stable and thats perfect for 2 4ohm kickers rated 600a piece. theres also amps that do 1000rms @1ohm stable if you want to keep it on the safe side.
$500 is enough money to get an JL 1000.1 i think on eBay? if you want to save, hifonics brutus bx1000d which starts from $200-250 ?
http://www.sounddomain.com check out the reviews here on name brands and models
and the sticky above: http://forums.caraudio.com/vb/showthread.php?t=45618
ryanbssc29
ryanbssc29
Waveland, MS
ChevCamaroRs89
