Amp for Alpine Type-R?
99vw
Considering the 60 amp fuse rating on the Blaupunkt I would assume it would have a bit of an edge on the Kenwood(40amp fuse rating) as far as output goes. That sub will only wire down to 2 ohms so if you found an amp that does around 700@ 2ohms it would suit the R nicely for a daily setup.
the kenwood is good if your at 2 or 1 ohm it will slam that sub nice
Have you ever installed one of the newer Kenwoods at 1 ohm? I don't know if it is a fluke or not, but I have seen two of the newer Kenwood Class D amps thermal after 15 minutes of play at moderate volume. They may be 1 ohm capable, but they sure don't seem to like it:crap:
Cadence TXA1000D. Some folks had good luck out of them, some havnt. The one that I used supplied sufficient power for me and never gave me a lick of problem.
They're not expensive at all, either. I sold mine used for 130 shipped in greattt condition.
I would recommend differently, but in that price range it's hard to find a decent quality amp with the power you need.
Well I see that I should try and stretch the budget so if I was able to stretch it to around $180-200 what would you guys recommend?
no only the 7k series. so the new ones ****? I haven't ordered any til I unload the old 1's.
brutus 1208 but they are about 240 + online I can sell you 1 shipped for 235 with a real factory warranty. it will give you 900 rms so it is plenty.
for 200 buy a good name brand here in the classifieds used.
99vw
99vw
Austin
SicAudio
