AMP for 2 12 inch kicker cvx
why only 3000 watts peak? I seen some CVX's take 5000 Watts peak each...
But for real dont worry about peak numbers they BS, those CVX are 750W RMS each, meaning they can take 750W continuously for a long period of time without damaging the sub. SO FORGET PEAK NUMBERS AND LOOK AT RMS NUMBERS
So you should be looking for a amp to do 1500W RMS @ 1 ohm.
I recommend a Sundown 1500d, they can be had used from here for around $350, and from what i hear, they are the best amps out there. Basically half of the members on CA have one.
Looking for a one ohm stable amp up to 400 dollars needs to be 3000 watts peak
3000 watts peak? LOL. How many RMS, not watts peak. I believe the CVX is 800 RMS, and I guess your getting the 3000 watts peak from the total of both CVX's Watts Peak. First lesson in audio, caps are useless, second never buy anything based off of watts peak, only buy off RMS ratings for Amps and Subs, which is the continous and actual output of the sub. So the two subs will give you a total off about 1600rms, and since their underrated you might get away with 2k rms. What is DVC yoy get a D2 or D1?
edit: welcome to the forums too, just read the threads and brush up. Learn early wish I did
Kicker kx1200.1(1200(at least)x1@1 ohm) - orion 2500d(badazz amp and 2500x1@1 ohm) - ma audio hk602sx(3600x1@1ohm) and a punch power t1000.1bd (tested at 1367x1@1 ohm)
strypersux
I Love McDonalds
strypersux
Tri Cities, Michigan
9seconlives
