Amp Fans
candyman206
I wanted to hook up two big computer fans to the bottom plate of my RF1000bd. I am thinking of cutting a few spots to mount the fans on the bottom of the amp. On one fan I want to have it with the polarity reversed so that one will **** and the other will blow. I thought of using and ACC wire, but I am not sure if this is how every body hooks fans up. Any help will be great. Thanx in advance
get a relay and hook all your 12v accessories to that. much safer for your headunit. your rem line CAN break by pulling too much current on it (~2amps even)
how would I do that. I tried to work with relays on my XBOX but I **** at it. I don't understand the different rows on the relay. Will I be able to hook up more than one thing, on one relay? I need power for the fans and my epicenter.
Get a relay, from somewhere like AutoZone. With the relay is a diagram for where the wires should go. Run a 12v+ from the battery or your power wire to the 12+. Use the remote as the "turn on" or whatever it says. You'll need a ground and the other wire is the power that you'll use for fans and such. That's how I have mine run, no problems.
candyman206
candyman206
Seattle, WA
candyman206
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
