amp dead...
agarabaghi
So fired up the boat today and the audio pipe amp is toast. Protect is solid and power is flashing like crazy. The sub makes a consistent popping sound. Unhooked both amps and plugged in just the other apsm1300 and everything was fine. I took the bad apsm1300 out and put it in my truck and got the same results.
Im guessing the humidity / moisture killed it? Gonna get a marine version of the apsm1300 and when the other one dies i will replace it with a marine version also... bummmmmer!
yea i can imagine that happening. Hopefully the marine version will prevent this from happening again. Ide go over the spot where there mounted and see if u can make it any more protected from water/humidity
PS- popping noises are never good lol
agarabaghi
agarabaghi
Orlando, FL
agarabaghi
