Amp cutting off!!!
PartyInThRanger
Ambulance with Bass
Alright here is my setup:
1 viper 600.1D running 2 Kicker CVR 12's
1 Xplod 500 4ch runinng 4 Xplod 5X8's
My amps + & - both run straight to 2 batteries located in the bed of my truck. I have ran this setup without trouble for about 2 months, but recently the Xplod has been truning off while hard bass is hit. The viper still runs so all i hear is bass untill the bass line is over then the xplod turns back on. I have checked all my connetions and i am stumped! //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
seems like you have a voltage drop which is affecting the xplod amp. the amp is designed to operate within a certain voltage range. when operating outside that voltage range, the amp may cutt off.
It is a low voltage problem that you have. Just because you have two batteries does not mean that you have limitless power on tap. All you have done is compounded a problem. Batteries do not creat power, they store it. You are taxing your alternator way beyond it's normal limits by trying to run the vehicle, the stereo and charge 3 batteries. Eliminate those two batteries and the draw they place on the alternator. Get yourself one good battery and a HO alternator. Do the BIG3 if you have not done it yet. I can see the additional batteries there if you plan on running the stereo with the engine off, but if the engine is on, all they are doing is damage without a proper isolator and a alternator that can deliver enough current to do it properly.
now u need a good alt. THat is why are gettin voltage drops. But if u get a good alt then u will not need the 2nd battery.
SO i laymen's terms what I am saying is get a good a good alt.
PartyInThRanger
Ambulance with Bass
PartyInThRanger
Middletown, NY
LBX2G
slater
    Oct 4, 2025
1aespinoza
    Oct 4, 2025
