Amp cooling space
I recently got my Amps wired up and curious about how worried I need to be about cooling?
The sub box is 1/2" from amps when the seat is up with a small gap above the box and that's it.
I've ran amps with less space than that as long as you have adequate electrical and not wiring the amp lower than what its rated for you should be fine but try moving the subs forward a bit if you can
Sent from my Z812 using Tapatalk
DAMONMCHALE
DAMONMCHALE
Longmont, Colorado
PittViper
