amp configurations
BILLYZ9
hi there everyone, just have some question/suggestions about what to do with my AMPS, nothing is installed yet. just wondering what i should run off what really.
head unit: clarion hx1
eq: eclipse 8 band graphic eq
amps: arc audio 2050, 2 channel 70x2 at 4ohm, freq. 55- 5.5khz
zapco ag 350, 4 channel 60x4 at 4ohm
rockford fosgate 600a4
rockford 500.1 mono-use this with my sub
speakers: two focal 6w audioms, 2 focal 5w utopias, 2 focal 4" utopias, 4 focal tn-51 tweets, 1 rockford hx2 sub-gonna upgrade eventually, i have the bi-ampable crossovers for crossovers 2 pair
and i eventually wanna get the 7" w utopias for my rear dash, and i want to keep the 6" 5" and 4" up front.
My suggestion would be to nevermind about the 7" in the rear deck. You're already going to have alot of bass coming from the rear and if you run midbass through the 7" woofers they are going to be localizable and take away from your front sound stage.
Am I reading it right you're planning on running a 6s, 5s, 4s and tweets up front. If that is the case you are really over killing your front stage. I would suggest one of a couple different scenarios.
1) Get the 7s put them in the front doors and use 6s or 5s in the kicks with tweets.
2) Put the 6s in the door and use either the 5s or the 4s in the kicks with the tweets.
A pair of 6s, 5s, 4s and tweets up front is something I would never recommend. I'm not saying a 4 way set up "COULDN'T" work but it is very unnecessary.
I use 6s in my doors with 4s and tweets in the kicks and do just fine.
Hope I helped. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
BILLYZ9
BILLYZ9
PITTSBURGH
adam71
