Amp config
joek86
A 6 channel Audison LRX6.9............... runnimg in a 3 channel mode FR L&R and sub (2 x 240W (4 ohms) + 1 x 280W (4 ohms) ) or 5 channel mode FR L&R RR L&R and sub, 70 watts times 4 and sub 280 (4 ohms))???????? for best sound quality.............
Joe
The first one but that's because I don't run rear speakers. My only concern would be that the front stage would totally drown out the sub with that amount of power to each. If possible I would run the front stage either as an active two-way or semi active 3-way and couple that with a really efficient sub.
I have a dual voice coil Focal sub so if I combine the + and- 's I can run at 2ohm which is 400+ watts to the single sub. Up front I am running Focal K2 Power 6.5 components. Give all of this, which layout would you recommend?
joek86
joek86
Rochester NY
helotaxi
