Amp causing subs to make a popping noise
Benschneider06
11
IL
//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
I just bought a power Acoustik GT1-4500D (2700watt RMS 4500watt MAX) amplifier and connected all the wires I had from my old amp(which burnt out). For some reason, without even playing music(completely muted) it just makes a *pop* *POP* *pop*. I have to press the breaker button on my battery(in place of an inline fuse) to get the popping to stop. Subs and new, amp is new, don't know why it's making this noise. I don't want to blow anything. Can anyone tell me what's going on?
I remember when I had an APSM1300 at high volume my subs would do a pop*pop*pop*pop* sound too untill I swapped amps and it never happend again but this was only at high volume yours is on mute
If I took the amp apart and posted a picture of the internals could you guys see the internal ground connections and tell me if that's the problem? I can't imagine it being the grounds. Non of the lights flash, flicker, or turn on or off
No way the amp is bad right out of the box..? Just because you don't like power Acoustik doesn't mean they aren't functioning products.
You never know. There are lots of amps that make it in to the market that don't pass quality control. One example is B-stock amps from overseas manufactures.
I would not take the amp apart. if its new and bad just send it back for repair. Taking it apart yourself could void manufacturer warranty. what kind of deck are you running.
Benschneider06
Benschneider06
IL
Mass Car Audio
