amp buttons
wow u gota do some reading bro. level is pretty much your gain,sub sonic should be set about 10 Hz lower then what your box is tune 2,lpf put it at 80,phase leave it off,bass boost leave it off, and i guess u would have to bridged the subs if its the right amount of rms for the subs
just take your time and follow 1mtx1's guidelines......remember to try and match the gain(level) to the head units voltage output.......ie; turn everything down on the amp, turn the radio up to maybe 3/4 max volume, then slowly adjust adjust the amp until everything comes together......th buttons and nobs can be a bit confusing at first but we all start somewhere. do a search on the nob duties and go from there...if all else fails...ask again and learn man. write it down and try not to blow anything up.
keegans
keegans
new zealand
1rockford1
