amp blows fuse??
newyorkjets00
ok i have 2 10s kicker cvxs there 600rms dual 2 ohms each.. here is the amp im using
http://www.sonicelectronix.com/item_...KAC-8101D.html
right now on the sub red and black together then then red and black with the white dots going to the terminal.. for both subs then bridged.. the fuse blows after 30secs and amp goes to protect mode but i got this weird metal block lookin fuse now it doesnt blow as fast but still cuts out on me all the time, whats the deal here? i know there not gettin enough power prolly 200 watts each how should i wire them together and to the amp?
Are u positive that they're wired to 2 ohms? Because my guess with this is that you have them wired to .5 ohm..(both the subs coils and the subs ran in parallel)
And your link is dead...it says the product isn't found..
Make sure they are wired like this:
-Amp's positive to sub #1's positive terminal (on either coil)
-That same coil's (on sub #1) negative terminal to the other coil's (on sub #1) positive terminal
-Sub #1's negative terminal (on that second coil) to the amp's negative terminal
And then just wire sub #2 in the same fashion and the amp will see 2 ohms...(two 4 ohm loads ran in parallel)
newyorkjets00
newyorkjets00
Lake Whitney
Pioneer~Saturn
