Amp Blown??/
Twista89
Quick question, so I was out driving yesterday when my subs just completely cut out. Went to look at the amp and it was still on, not in protect mode or anything. Swapped out RCAs but still didnt get any feedback from the subs. Couldnt make the amp go into protect mode either. Did my mbquart just take a crap on me??
I havent checked it today but it wasnt even hot when it stopped working so idk, I also left it running for a while and the amp didnt even get hot like it usually does...imma go take a look at it in a couple of hours but my wiring should be good. I had my 4 channel running the same wiring and it works no problem. Like I said the amp turns on and the green light comes on it just doesnt play anything.
have you tried feeding it a different audio source? do you have an ohm meter to check for dc voltage on the speaker outputs, or that you have good 12v input at the power and ground cables? did a speaker wire come loose?
Twista89
Twista89
Chicago
akheathen
