Amp Benching?
MOST IMPORTANT THING IN THE BCAE LINK:
Test Data:
The following data was taken in a test to show how calculating power when using the voltage across a speaker's terminals instead of the voltage across a non-reactive dummy load will result in false output data. The frequency is the test frequency. The voltage is the voltage that was measured across the terminals of the load (either speaker or dummy load). The power is the calculated power using the speaker's nominal impedance (4 ohms) and the voltage across the speaker's terminals at the various frequencies. The voltage across the dummy load will be virtually the same across the range of frequencies so only one voltage reading was necessary. The amplifier is capable of producing only 205 true watts (RMS power). When using a speaker, it appears to be able to produce as much as 376 watts (which it clearly is not capable of doing).
Check the table:
Check the table:
sorry so what are you getting at? using a speaker will screw up your readings? so you wnat to use a dummy load or resistors?
also what frequency should i be using with the dummy load/ resistor bank? 50 or 60 hz? (ps i will be using a frequency generator to give me the wave)
Wouldn't it be different depending on what frequencies that specific channel or amp is playing.
no, "dummy loads" are resistors. The resist at X ohms regardless of frequency.
an amp may produce slightly different power at different freq's, but it shouldn't vary much. That's why power ratings SHOULD (and used to) be specified as X watts into Y load +/- NdB from 20-20khz.
so since dummy loads cost to much looks like i am going to buy a bunch of 2ohm, 20watt resistors! i got a price of like 100$ shipped to my house! lol!!
fun times hooking them up in a 10x10 setup lol!!
Take your multi-meter to some home improvement stores and test hot water heater elements for DC resistance. I had 3 12 ohm elements that could be used as a dummy load, and I submerged them in automatic transmission fluid to keep them cool. Unfortunately, I can only find 2 of the three //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
CrazyKenKid
CrazyKenKid
Canada
gunz4me
