that type of dummy load would work, yes. are you wanting to test at 8ohms, though?
Also, keep in mind the kind of power you expect to have. Would 200w be enough? Do you need to buy a couple and wire them in parallel/series? These are things you need to think about. Oh, and those things will get HOT! do not touch!!! Some use their own ways of cooling (oil, water, etc)... you'd have to search on this. google should help.
Now, again, some say that you don’t need to put resistance on the amp; that it’s clipping point is the same no matter the load. I’ve asked about this and was shown proof that the same gain position on an amplifier can clip with one load, and not on another.
This is something I haven’t tried to prove myself, but I have seen the evidence and I believe it.
If you do this at your school make sure the power supply is enough to handle the amp. IOW, I wouldn’t try to rock an amp full tilt on only a 5amp power supply. I use a 55amp PS to power my car, and also for my test bench. It’s probably overkill. Just make sure you don’t use too little.
You’ll probably want help setting up the scope. You should only need to use one lead on a single channel; that lead may need to go only to the positive terminal on that channel, or the negative on that channel. In the case of my PDX’s, I just put the oscope lead to the + of channel 1 and got signal. On channel 2 it had to be put on the – terminal. There’s reasons for this that were explained to me but it was much more than I can regurgitate now.
Just be careful. I’d get someone who knows wtf they’re doing to help you out initially so you don’t fry something. Or at the least, you could easily knock out a circuit in your house. It could very well happen, too. I know. Trust me!
