Amp & Speaker Match Help... (noob alert)
bkim921
I'm looking into buying the Precision Power PPI P900.4.. It's got 2 different rating.. which one do i match with the speakers? Thanks for the help.
RMS Power Rating (14.4V):
4 ohms: 145 watts x 4 chan.
2 ohms: 225 watts x 4 chan.
Bridged, 4 ohms: 450 watts x 2 chan.
RMS Power Rating (12V):
4 ohms: 100 watts x 4 chan.
2 ohms: 150 watts x 4 chan.
Bridged, 4 ohms: 300 watts x 2 chan.
14.4V is when car is running
12V when it's not
Conservatively, go by the 12V since you know you'll always be getting that power.
283
215
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
You tried the external relay with no success? If so, how did you wire it?
18
Heads up, those coaxial units I listed above, have a broken tweeter stem. If you go the pioneer route (and at this price, I definitely would) get...
15
bkim921
bkim921
los angeles
neo_styles
Brendon Jenness
    May 8, 2024
    May 8, 2024
