American Bass VFL Hybrid 4480.1D Mini
audiobaun
2,130
USA
Review of Amplifier:
Post name, details and review of the equipment you're reviewing. This forum is for reviews only! No questions should be posted!
The American Bass VFL Hybrid 4480.1D Mini Mono amp that I got From Mr.Mylows10, is Very Impressive.I havent been impressed with a mono /bridged amp for quite some time, and I can say this one did.I ran it @2ohms for approx 45min to an hour on a pair of old school AudioBahn USA Made Aw1008t DVC2ohm subs 1k rms 10s,in 2.06 cuft@32 htz per chamber, at approx 1oclock position, and they hit very hard and clean/smooth.I then ran it to one sub @1ohm load, @approx 12 oclock position, and she was quite impressive,and ran for approx another 30 min pretty hard and heavy,and the amp stayed quite cool to the touch,.Ive bought several amps over the last 5yrs, and havent found anything that really out performs my Cheater old school Zed Autoteks(BTS 7150s) on the lower end running @2ohms mono,and have always been disappointed, until now.I am very pleased with the performance this amplifier delivers,its small foot print,as well as its craftsmanship.Very nice amp.I recommend this amplifier to anyone needing real power for your subwoofers,and it is a real space saver as well that performs outstanding! I have another on the way,thanks to Mr.Mylows10,and the 4ch in a day or two.cant wait to get all three going,and soon to replace all four subs,as 2 are blown from a bunk buy(2 ive had for over 10 yrs still going strong).I thank You Mr Mylows for recommending this amplifier,and delivering a smile on my face and a quality made piece of Car Audio equipment.I thank you sir.looks like I will finally put my 15+yr old cheaters at rest for another system for the time being.Great amp people,worth the money spent for a change:santa:
I believe that the RMS specs @1ohm load was 2250 watts,and 4500watts max.the Size is 13.5 clearance of the terminals x 6.50 x 2.25.Small and compacted little Beast
1ohm stable
input sensitivity=6v-0.02v
low pass filter=50htz-220htz
subsonic filter=off-50htz
bass boost=6db/12db
freq.response=20-250htz
signal to noise ratio=85
efficiency@4ohms=over 90%
tdh@4ohms=
damping factor=150
fuse rating=120a
This is the only specs I have on this amp,N/A @4/2ohms
Hybrid Mini Amp., Golden and silver heatsink, RT-9004 Class AB 4-CHANNEL 75 Watts RMS at 4 ohm 300*170*45mm
RT-5501 Class D 1-CHANNEL 1000 Watts RMS at 1 ohm 300*170*45mm
Merry christmas to all of you ^^
Did I miss something??//content.invisioncic.com/y282845/emoticons/ot.gif.1ccdea14db89b4c1e3b73336d794b1d2.gif
1000 watt amp with 40 amps of fusing? //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
I just picked up a brand new american deluxe jazz bass and I want to take off the knobs in order to remove the plastic name plate that is below it. What size of allen key do I need to remove the lower knobs? The bass came with an allen key for most of the knobs but not the lower ones. thanks.
audiobaun
audiobaun
USA
mylows10
SlugButter
    May 4, 2024
slater
    May 2, 2024
