Am i calculating my volts right? Please take a glance. Trying to set my gain
scheibler
Ive got an alpine mrp m350 amp that does 350 watts @ 2 ohm and a 4 ohm dvc ssa dcon 10". Im trying to run the sub at around 300-350 watts in parallel at 2 ohms. I want to accurately set my gain and found the equation that you are suppossed to use to find the optimal volts.
Voltage = sqrt(rms x impedence)
So is this what i would do for my 4 ohm dvc woofer?
Voltage = sqrt(300x4ohm)
Voltage = sqrt(1,200)
Voltage = 35
Or is it this since im running the amp at 2 ohm to a 4 ohm dvc woofer
Voltage = sqrt(300x2 ohm)
Voltage = sqrt(600)
Voltage = 24.5
scheibler
scheibler
St. Louis, MO
bubbagumper6
