aluminum or copper voice coil?
Usually weight and power handling. In general, copper can handle more power but it weighs more. IMO, an aluminum coil sub will respond faster, sound better, but usually can't handle as much power until you get into larger coil diameters or heavier gauge windings.
Dont more often then not, SQ oriented subs have a copper coil, therefore a lower Fs?
Fs is the resonant frequency of the driver. The Aluminum coil option is for people who are going to really abuse the driver and push it too its power limits and want a little more peak in their output.
All things considered, copper is the superior conductor. period.
Aluminum is cheaper //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
ok i got ya now
This is the only answer.
Aluminum cools faster but I thought part of the job for the former and the gap is to cool the coil?
A heat conductive former will draw heat out of the coil and cooling vents for the gap, exhaust the heated air.
Aluminum wiring in houses tends to burn, that's why they switched over sometime in the 70's for safety reasons.
I would imagine you would have to have a lot heavier gauge aluminum to equal the power handling of copper?
CHUCKmfnNORRIS
CHUCKmfnNORRIS
CT
iLL Ridge
    May 24, 2024
