aluminum or copper voice coil?
Aluminum wiring in houses tends to burn, that's why they switched over sometime in the 70's for safety reasons.
This was due to dis-similar materials on the connectors with varying expansion ratios loosening over time - thus creating heat from the loose connection and eventually fires.
The real factor is the ratio of motor force factor to the MMS and not just MMS... unless you are running a very high frequency where the downward shifting FS will hurt score with the copper.
Example:
Z v.2 Copper ratio is 0.59
Z v.2 Aluminum ratio is 0.62
My testing showed zero SPL difference between the two coils -- in theory the aluminum should have been 0.1 louder based on the ratio but in real life they metered the same... up until over 6kw where copper was a bit louder as power compression was lower.
But on the SA-8 :
Copper : 0.51
Aluminum : 0.54
In this case they are also still very close... but we tested at 68 Hz -- so the much higher FS of the aluminum coil overrode the ratio and gave us a gain of ~0.8 dB or so.
alum cools faster
The thermal conductivity of copper is considerably greater then aluminum... //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
This really isn't rocket science.. with one aluminum and one copper coil of equal mass, wind height, adhesive, former, ect, the copper coil will handle slightly more power.. additionally, because the windings of the copper coil will be considerably smaller you can use a tighter gap for increased BL...
The only reason to use aluminum, as far as I am concearned, is to save money.... (same as with house wiring)
copper takes longer too cool. you wont have a copper and alum coil the same ww and same weight,lol. tighter gap than copper use alum flatwound. are you mad frenchy?
If you want to compare apples to apples you need to compare two coils with the same mass... period... and to be fair in other terms of performance wind height should also be the same... I can get aluminum & copper round in a wide variety of gauges as well as flat, and edge wound, at any wind height... so there is no reason why a direct comparison shouldn't be made...
As far as copper taking longer to cool, try looking up the thermal conductivity... //content.invisioncic.com/y282845/emoticons/*******.gif.a649d21efc0d1fd4890a6428166586c1.gif
if both coils are = then the alum will be louder. the copper will handle the power betterfordaily though...
SPLsens is based on BL, Re, Mms and Cone area. The difference between Cu and Al is 3 times the mass but only 2/3rs the Resistance. There is a thermal conductivity difference to in favor of copper, but we'll ignore large signal differences for now.
There is no way to tell is Cu will be more or less sensitive than than AL because the Mms also depends on the rest of the soft-parts. For example, lets say the coil only made up 1% of that mass - In that case copper would out perform aluminum on all fronts. Now lets say it made up 99% of the moving mass - AL would be the clear choice.
Would there be significant difference in coils of equal mass and height as far as gauge of the coil wire and thermal power handling?
Yes, there would be a difference in mass if the coils were even somewhat similar (if they were of equal mass they wouldn't even be close)... example :
4-layer copper / 63.5mm former / 45mm WW / 7.01 ohm = 0.48mm diameter wire / ~113 grams / 67.74 mm OD
4-layer CCAW / 63.5mm former / 45mm WW / 7.06 ohm = 0.54mm diameter wire / ~40 grams / 68.19 mm OD
If we try to make them of equal mass the CCAW coil would need to be about 97mm long given a DCR close to the above (7.17 in this case).
Using just a sample driver with 110-grams non coil mass -- top plate gap adjusted to be equal from CCAW to the Copper :
COPPER:
Motor Force Factor = 109
Total MMS = 223 grams
Ratio = 0.488
CCAW:
Motor Force Factor = 84
Total MMS = 149 grams
Ratio = 0.563
In this scenario the CCAW would be about 0.5 dB louder assuming FS isn't having a big impact on the score in your setup.
But to examine Kyle's point further about coil mass as a percentage of total mass lets make the non-coil mass 250 grams :
COPPER:
Total MMS = 363 grams
Ratio = 0.300
CCAW:
Total MMS = 289 grams
Ratio = 0.290
Note that the CCAW coil now has a worse ratio.
Moral of the story ? It depends on what you goal is in the design process... copper, aluminum, and CCAW all have their place based on application.
CHUCKmfnNORRIS
CHUCKmfnNORRIS
CT
iLL Ridge
