CHUCKmfnNORRIS
plan on getting an ssa icon and have the choice of aluminum and copper. what is the difference?
Dont more often then not, SQ oriented subs have a copper coil, therefore a lower Fs?Usually weight and power handling. In general, copper can handle more power but it weighs more. IMO, an aluminum coil sub will respond faster, sound better, but usually can't handle as much power until you get into larger coil diameters or heavier gauge windings.
ok i got ya nowFs is the resonant frequency of the driver. The Aluminum coil option is for people who are going to really abuse the driver and push it too its power limits and want a little more peak in their output.
This is the only answer.Fs is the resonant frequency of the driver. The Aluminum coil option is for people who are going to really abuse the driver and push it too its power limits and want a little more peak in their output.
The coils are not equal in this case, so the aluminum have a little higher thermal limits.if both coils are = then the alum will be louder. the copper will handle the power betterfordaily though...
X2 MMS is a HUGE factor in efficiency.alum cools faster yes but why its louder is weight.
This was due to dis-similar materials on the connectors with varying expansion ratios loosening over time - thus creating heat from the loose connection and eventually fires.Aluminum wiring in houses tends to burn, that's why they switched over sometime in the 70's for safety reasons.
The thermal conductivity of copper is considerably greater then aluminum... //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gifalum cools faster
copper takes longer too cool. you wont have a copper and alum coil the same ww and same weight,lol. tighter gap than copper use alum flatwound. are you mad frenchy?
